Thanks for your help in advanced,
I have 1972 50hp Johnson, it was running fine the other day on the water and then just stopped.
It will only start on one cylinder and yes it has fuel, compression and spark to the other.
It will idle on one cylinder and even if i just cover the other spark plug hole with my thumb it instantly stalls. it must have to do with the increase cylinder pressure.
Does anyone know what I am looking at to fix the problem and is it an easy fix?
Thanks
David
Thanks
David
