My 1968 5 HP Johnson is somewhat easy to start when cold, 7-8 pulls usually does it. When the engine is warm it's a real bear to start. In fact I usually wait for it to cool off then give it a try. Carb has been disassembled, thoroughly cleaned and rebuilt. New plugs points and condensers.
Additional questions that may or may not be germain to this situation are:
1) Is it possible for the timing to be off and cause this problem?
2) Could tweaking the point gap be an issue?
3) Could the gap between the flywheel and the magneto affect this situation?
Any additional information is much appreciated.
Thanks,
vzapp
Thanks,
vzapp
