Pink Shibi
- Mar 7, 2013
- 18
Ok, so I am back my boat worked great for a while after my help here last time so I though I would come back.
Here is the story in easy to follow steps.
1. Put my boat on the lemon lot on base
2. someone (probably kids by the size of the footprints) turned on my killswitch and left it on.
3. took boat out to go fishing
4. battery is dead
5. jumped boat - ran fine so decided to put it in the water and pull the battery from my truck and jump it in the water.
6. jumped boat didn't start, tried again, nothing. at this point I have probably flooded the engine.
7. I look at killswitch it is visibly burned looking
8. reroute wires to exclude killswitch jump again tries and fails to start. then nothing. I bring boat home with disappointed friends and no tuna.
9. I look at wires. Notice several are significantly more corroded than I remember.
10. I get new battery and start testing circuits. nothing is working or working subpar.
11. decide to rewire boat myself. (bad decision by the way)
12. 1200$, lots of sweat, and three weeks later I have rewired boat(accessories mostly) myself and learned a lot about 12v boat systems I also moved battery to center console to avoid bilge water corroding my wires.
13.i now have everything rewired. except the engine harness and man the old wires were amazing in the fact that some still worked at all.
14. The power for the gauges (fuel, trim, battery voltage, and hour counter) in the console seems to be coming from the trim gauge. it has three wires from the harness white, purple and black. White = ohms from sender purple=ignition power black=ground. (looked up diagram)
15 go to connect ground and it sparks. I am seriously confused. there is 12v running from the black(ground) wire when checked with volt meter(also wire gets super hot super quick so I taped it off and left it be for now).
16. I hook up the trim switch it has redwhite = power bluewhite = up and greenwhite = down. all good to go on that front
17. I am in the back of the boat and have to raise the engine for something. I hit the trim tabs on the side of the motor and not the console
18 they are reversed!! down is up and up is down.
19 I am now thoroughly confused.
20 I NEVER touched anything in the engine.
21 I now touch the engine and trace the wires to a relay. I take it off and part of the mount is melty.
What have I done to the engine?
why is there power from a ground cable?
why is the trim on the engine working backwards when I never touched it?
oh and how do I fix it
thank you and I hope I have explained my problem thoroughly enough extra data is as follows
2001 90hp Johnson oceanpro model number j90vlsig
the relay that's mount is melty is Johnson part number 586224 or siemens vf4-15f21-z11
the gauge is a faria gauge don't know model number but I looked it up and I am connecting them correctly since the wiring for them all is the same.
last I used to be an electrician and I still manage to shock the **** out of myself(facepalm).
Pink shibi, out...
4. battery is dead
Pink shibi, out...
