samsgunner
- Sep 22, 2013
- 3
I have a 1976 Evinrude 70 hp motor, model 70673d with a power pilot control. Yesterday was the first time I had the motor on the water. The control handle engages the transmission smoothly when the control arm is advanced and increases the idle speed slowly. Reverse works well. Where I need some advice is the handle had to be pushed to an almost horizontal position before the motor would take off to planing speed. Once it engaged, I had a very small amount of travel from that point to the maximum travel distance of the handle. Please advise is this adjustment is made at the control box, motor, or if my cables are simply in need of replacement. Thank you
