hockey103b
- Jul 25, 2013
- 10
Trying to remove lower unit to replace impeller. Like many of the posts I have read, the lower unit will only go down about 3/4". I have removed the four lower bolts and the side metal plate but cannot figure out how to disengage the gear shift. I don't see any bolts that attach to the shifter, only a circular pin that I can't do anything with. Also, in the midst of messing around with the lower unit, my throttle lever has now locked up. HELP!!!
