Slojoe
- Sep 13, 2009
- 32
I no longer get a click when pushing in the start key and the motor won't fire. I don't see a manual choke rod like on the earlier motors. Instead it has a black solenoid with a bicycle air valve and a red lever that moves back and forth.
Can someone tell me the testing procedure for the electrical primer solenoid. Is there a way to bypass it to get the engine started? What about the air valve, what is that for, should i try pumping it up? What does the little red lever do? Finally, where can i find a new solenoid if it ends up being defective?
Motor has great spark, compression, fuel delivery, strong batter/starter, ran perfect all summer, now, no primer click=no start. Boat is on a mooring so i would like to gather info here first, so that i have the right tools on hand the next time i row out for a look. thanks
