I have a 1993 Evinrude 60hp and think I've narrowed down my problem, but could use a second or third opinion to confirm.
Bought the boat in May. It would start only if I charged the battery the same day I used the boat. Bought a new battery, charged it fully, boat starts fine. Run the boat throughout the day and my Humminbird shows somewhere between 11.4 and 12.2V. Never higher. Motor won't start on 3rd day of use. I can jump it or re-charge the battery, but eventually with enough use, she won't start (cranks, but no spark). I have started it and then disconnected the battery and she continues to run.
From my limited understanding of the electrical system, I have surmised that the Stator is working, since the motor continues to run without the battery connected. I suspect the Rectifier/Regulator is bad, given that I'm not seeing any battery voltage higher than 12.2V during use.
What say the group?
What say the group?
