Woodonglass
- Dec 29, 2009
- 25,924
Starts and Idles Great! When I try to go to WOT she only goes to about 30% and thats it. Does not appear to have a miss. I will be checking compression this week. 2 weeks ago I ran her for about 15 mins like this and she finally broke loose to WOT and ran great. I throttled back after about 5 mins, and she would not go back to WOT. Pulled her out and she started puking "Gassy Oil" out the bottom of the lower shroud. Pulled the shroud and it appears to be coming from mid point or higher on leg. I'm thinking maybe a stuck float or crap in the carb but fuel filter and bowl do not appear to show to much trash.
Help!!! Less than 4 hours on Total motor tune up including Carb rebuild, ALL seals (Upper and Lower), Plugs, Points, Condensers, Mags, you name it they got replaced with NEW!!! She ran Great for the first couple of outings and then this started. I'm NOT a motor guy so I'm looking for some advice on where to start. My B.I.L. did all the work on restoring this motor 2 yrs. ago but since has moved to Virginia so I don't have his expertise except by phone. Any one with experience with this old motor would be a blessing!!!!
