Stinkbate
- Sep 6, 2013
- 3
Hi boaters, This is my first post but I have been browsing the site for a while. Thanks for all the helpful archives that aided me to rebuild my leaking trim cylinder. So detailed were the posts that I never had to ask a single question till now.
My dilemma came from bleeding the air out of the cylinder with it tilted backward on it's mounts, the fluid would just spill back out. It's tilted because the transom is not flat, but undercuts at an angle under the boat. (I have a pic) Even with the tong on the ground, the angle to steep to retain the fluid. I noticed that there are two extra set of holes for the lower pivot bolt so I removed the trim assy. and mounted it on the outer most set of pivot holes. Now the cylinder is perfectly level and bleeding went without a hitch. But I was worried about leaving it that way and after the bleed, put it back to its original position.
My question is, what would it hurt to leave the trim assy in the other holes? Why are they there? It does not effect the trim angle as the engine pivots on it's own mount and the stops and tilt are unaffected. The extra holes only effect the ram shaft angle that meets the motor?
