I recently purchased a used 2003 Evinrude 225 that came the tach, voltmeter and a few other gauges. Engine runs great. The main harness cable from the engine has several plugs on the helm end: one for the tach, one for the ignition, and one for the shifter. The tach works fine but none of the lights on the gauges work and the voltmeter is not working. The guy I bought this from literally cut out the dash panel when he re-powered his boat so all of the gauges were still daisy-chained together. I simply installed them the same way there were installed in his dash panel thinking it was correct. Do these gauges get power for the light circuit from the main harness that plugs into the tach, or does a separate 12v connection need to be attached to the tach for that power? Regarding the Voltmeter there are currently only two wires going into it: one is the lighting circuit and I presume the other is the 12v source from the Tach. At least that is what I think it is. Shouldn't the voltmeter have three wires on it: 12v source, ground, and lighting? If yes, is the one from the tach the 12v source or the ground?
Thanks in advance for your help.
