barry light
- May 2, 2009
- 19
I just replaced the starter solenoid for the 3rd time in 2 years. Bought originally from NAPA, who sells marine parts ( have bought impellors from them). Their part numbers are the same as Sierra Marine, so I am assuming that their part is the same manufactured part as Sierra. Can anyone verify this?
This NAPA solenoid has a 2 year warranty, which is good, but when it goes bad while on the water every few months, ain't good! I took apart this last bad solenoid and could not see any visible issues. Evidently the coil windings are bad, as when applying voltage to the switched terminal, it willl not pull down the solenoid. Is there any way to check the windings?
I saw a year old post from someone having the same problem with a 98' 115 hp. After he posted several times with several responses, and still having the same problem, he took it to an expert, and the expert said that he quit using Sierra parts because of problems. This expert installed an OMC solenoid, and the user said he has not had any more problems.
Not trying to "bash" any distributor/manufacture.
Has anyone got a comment about my issues, and questions? Especially, if the NAPA part is same as Sierra? I did replace an impellor on a 40 hp Merc last year with a NAPA part ( thinking it also was same as Sierra). This impellor was in "yellowed" packaging and might have been sitting on the shelf for a while,. That impellor did not last one season.
