I could use some advice. I'm new to outboards, but I've been doping my homework.
I'm working on a 95 Johnson FastStrike 150 hp v6 60 degreee looper.
The motor will start right up when it is cooler than around 85 degrees F. But when it gets warm outside it will not start. The motor turns over but it will not kick up. I thought it might be bad thermostats so, I tested the motor without the thermostats installed.. same problem.
I talked to a dealer and they convinced me it was the OIS, so $86 later with a new OIS installed it still will not start when it gets warm outside.
Has anyone else ever had this problem? Any suggestions?
Thanks,
Shem
Thanks,
Shem
