thyNemesis
- Apr 19, 2013
- 73
I am having charging issues with my boat. Tested the battery charging circuit and it is only reading +12v. Batteries are not charging.
I'm looking to remove/replace the rectifier/regulator, so I called the local parts department and it runs around $100, Wow!
So, I am wondering if anyone has opened up this unit and repaired it themselves. I've read how others have installed an external
brige rectifier from RadioShack and the report it works fine. I, however, would like to see if I can open the blackbox and replace the internal rectifier/regulator myself. Does anyone know if this unit is epoxy incapsulated?
Thanks.
Thanks.
