sledhead26
- Sep 8, 2008
- 33
I have a 1970 9.5 that I've been messing with for a while but i can't get it to run off the choke. It has all new fuel lines from the tank to the carb, new fuel pump, new upper crank seal, new water pump, new plugs. I've cleaned the carb multiple, multiple times. I've reset the points. I'm running it in a barrel and have a fan on it to push the exhaust away. It starts great and idles great on choke but as soon as the choke is pushed off it has a bad stutter about every two seconds and will eventually die. It will run at higher rpm with the choke off but it still stutters and doesn't run very good. Not really sure what to try next. Any suggestions would be appreciated. Thanks
