Re: 1977 Johnson 35 HP Seahorse jumping out of gear?
Ok, sorry for the long delay, kind of got caught up in work. I finally got a chance to troubleshoot this a little more. After disconecting the shifter cable, I found the motor shifts just fine manually and does not pop out of gear. I started to look a bit further into whats going on and this is what I found. Turns out it looks like the previous owner used a bungee cable to hold down the shifter all the way forward in order for it to stay in gear. I thought this was odd so I took apart the shifter to see why they would have done that. Here is what I found.
They had screwed in another screw and used slingshot material in order to hold the shifter forward. After removing it and playing with the linkage adjustment, I can only get fwd or rev, not both. If I adjust it so it stays in forward, it doesn't have enough throw to get it into reverse. And vise versa. So, my thought it that the shifter itself doesn't have enough throw to get it into both, but its the original shifter so I can't see how that would be. The second thing I thought is maybe the cable is too long? Too much play? Its a solid metal rod inside a casing.
I don't have much experience with boats, but it seems like a pretty simple setup. So could this be as easy as needing a new cable? Or a little more complex and needing a new control box?
Thanks in advance from this boat newb.
