I have an outboard Johnson 9.9HP motor runs and sounds fine, but is not responding well to the throttle shifter like it should. I have to make several attempts, back and forth, with throttle shifter to get it into high speed and may not be getting into top speed when shifter is all the way forward. Same with reverse. Forward and reverse both work so transmission is fine. I am assuming that there is something wrong with a part that connects the cable from the shifter lever in the boat to the engine, but not sure.
Could anyone tell me what the possibilities could be?
Also, would there be an online parts diagram that would help. I am thinking that I would may have to determine which control mechanism/manufacturer was used for bass tracker at the time to get a parts diagram or possibly call Basstracker and ask them.
Thank you
Mike
Thank you
Mike
