Helping a bud with this motor that has been run hard in saltwater all its life. Referring to the parts diagram in the link below, here's what I found. Spring#81 is hanging loose on the end of Control Lever#37 and I do not have a service manual to help figure it out. Also, found one washer that I believe is Shim#39 on top of the powerhead. Not sure what else is missing and where it should be connected. Any suggestions?
Johnson Cylinder & Crankcase Parts for 1985 25hp J25RLCOS Outboard Motor
