firemanfitz
- Aug 14, 2009
- 36
Bought this 1851 seaswirl with this evinrude and been on it three times with no problems. Today things were working until I turn the motor over to go home from fishing it seemed to be chugging like weeds on the prop. Checked it out and all was clear. Continued to go and still chugging, as I throttled down the engine quit and would not even turn over after, dead. All gauges seem to work along with the fishfinder/ gps. Saw a 15 amp fuse that was blown and it appears (red wire) to go to battery switch and back out to maybe the bow (not sure) hard to see. Switched the fuse and still nothing. I did have an electrical smell under the engine cowling , but no visible burnt wires. I did replace a new the fishfinder/gps last night and hooked it up to the main fuse panel only, but all is well under there unit still works. Taking it in tomorrow (hopefully), but just wanted some possible input. Thanks Mike
