midsized johnson
- Jul 28, 2005
- 155
How do you keep the timing advanced but back the throttle adjustment off? The engine runs great in the water, idles around 1000 rpm. However, the idle is pretty high, 1400 rpm at idle on the earmuffs in the driveway. All the adjustments got out of whack when I replaced the lower unit. Long story, but I had an older style lower unit which required a different linkage than the newer one I replaced it with. I had a guy come over and adjust everything, but it wouldn't run with back pressure in the water. I upped the idle to 1400 and it does great in the water. Shouldn't I be able to back the idle back to closer to 1000 rpm's on the earmuffs and still fire in the water?
