riverrat 2
- Aug 27, 2013
- 23
Does anyone out there know how many packing washers should go in the high and low needle valves? Mine were sucking air so bad . All I could find was a few little pieces. I know they come in a pkg of 4. does that mean 2 for each valve or 4 for each valve.Would appreciate your help. I am going to replace the impeller with a kit that arrived yesterday but when she fired up the one in there worked so I thought I could put it un the back burner and start on the stay running problem til I saw water coming out where it shouldn't. Thanks for all the help so far guys.
