Hi all,
My motor runs great when warm. However, at cold start it runs for 5 seconds and will stall, unless I am quick on the throttle and up it to half throttle.....obviously opening up the throttle plate to let it breath. Choke solenoid and choke linkage/plate position is good and works well. Idle setting is good as once warm it will idles perfectly. Looking for any ideas? Can the warm up lever setting be increased or is that the wrong approach?
