outboardsusa
- Sep 7, 2013
- 66
Got me a 1959 Johnson 5.5 last year I believe for the old pressure tank motors but someone seems to have installed a fuel pump on it which made me happy, it has two connectors a long pointed one and a shorter rounded one that runs to the pump, I guess that is a connector to the newer type tank that came out about 1960, that is the type I need to get? Also at the prop there is no cotter pin and hub holding on the prop, does this motor have shear pin? It is not what I'm familiar with.... thank you...
