battleofarnhem
- Aug 30, 2013
- 2
Hello All, it is my first time posting on this site.
I just picked up a 1956 Johnson 30 HP. The motor has been in my family for close to 50 years. For the past 30 years she has been sitting in my fathers garage.
I just resealed the lower unit. I pressurized the lower unit and passed. (Thanks to the help from this message board) Now with the new water pump installed and the lower unit back on the outboard. I have run into a question about Oil and gas mixture. A guy at my local Marine parts store told me to use Johnson XD50 Oil and to mix it 50:1. I even confirmed with him "So I use 50:1 in a 1956 johnson that use to call out 24:1?".
I just wanted to check with you all and see what you recommend? And is XD50 the best oil to use?
Thank you in advanced for your help!
-Brandon
-Brandon
