outboardsusa
- Sep 7, 2013
- 66
Can you use modern synthetic or other 2 cycle oils for older Johnson - Evinrudes?
Thank you the oil I got says use for 16:1 8 ounces per gallon and 25:1 is 5 ounces per gallon, so it's best to run 16:1? Back in the day when I had motors like this it was one quart of 30 wt per 6 gallons, I think it was non detergent oil we used, but I will take you advice, thanks again
Thank you.... bcThere is good advice on fuel mixes on the engine FAQs board. See http://forums.iboats.com/engine-fre...-oil-mix-most-motors-covered-here-158072.html
