Re: 1966 33hp evinrude ski twin model number 33652d
Hello again kid. The fuel pump sounds ok, actually. I would focus on one issue at a time. Get the carb cleaned and rebuilt (don't skip the welch plugs), then test the motor. If it's still wonky you can move on the the fuel pump. In the mean time, one way to the condition of the fuel pump is to squeeze the primer bulb prior to start. It should get and stay nice and firm after a few squeezes, if the pump is good. If it fails to do so, then the pump may be bad. You can also get the motor running and manually squeeze the bulb as the motor starts to die. If it pick up after you squeeze the pump, then that is another sign the pump is failing. If the pump is in fact bad, I think you'll have to buy a new/used on because this particular model of fuel pump cannot be rebuilt.
Here's a link on how to set the carb needles as well.
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle va /lve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, wating for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
