\\blacksheep
- Sep 3, 2013
- 3
Good morning Guys
I have a 1963 evinrude 10hp sportwin #10302E I bought this motor this year, I would like to remove the carburetor to inspect the hi speed valve. I am getting what can only be referred to as an oily froth (alot) on the inside of the exhaust housing , intially I thought I was getting some type of blow by from the lower unit because I was getting water in the gear case, I changed the O ring on the shifter assembly it fixed the water\ oil gear case issue but I'm still getting the froth.
The problem with removing the carb is there doesn't seem to be enough clearance between the carb linkage support and the lower engine housing to be able to get past the studs holding it to the engine?? I have a hard time believing the entire engine has to be removed from the lower housing just to remove the carb? does anyone have any tips or suggestions they would be greatly appreciated
