Hey all
I had my boat out yesterday and noticed that the motor was smoking a bit more than usual. I know on cold start ups it is normal to see smoke until it warms up but this happened when i was coming back to the launch at low rpms and speed.
I read about the vro units on these motors and some folks had to rebuild the pump in order to get rid of the excessive smoke. Is there a way to adjust the injection percentage on these units or anywhere else on the motor to adjust the mixture?
At high RPMs the motor runs fine, I also noticed that the primer bulb is never really firm, so maybe i have a leak somewhere and this is why the oil injection is compensating with injecting more oil than normal? Like I said it only smokes at low RPMs.
The motor has about 30 hours on it since it was re-built. I had another problem which was the shift assist switch that i ordered and replaced cus the old one was sticky.
Any feed back and ideas would be great, thanks
Lester
Lester
