Greenkarson
- Sep 1, 2013
- 14
I have a 1971 evinrude 50hp electric shift. Just got it a few days ago. Got it running with muffs in the garage. Motor starts and runs beautifully. Shifts from neutral to forward no problem. And back to neutral no problem. But nothing in reverse. I've done all the standard test. There is power to both wires going to solenoids when in reverse. Flushed out lower end couple times replaced oil with the C type. Still the same. Removed solenoids and grounded them using a pair of booster cables they both seam to work fine when I put power to them. I put it all back together still the same no reverse. The one thing I did notice is that the solenoid plungers are sitting a little over 1/16" down into the solenoid. But these are the factory solenoids. So I figured that was the way they were supposed to be.
Does anyone think that the solenoids actually may have went out of adjustment on there own? Or any other ideas what my problem me be?
