Re: 1977 140 evinrude cooling system
What small screen holes???
The water in the V-4 exits the prop and the two holes located just below the cowling under the engine cover. While running on muffs you only get a small exit of water....... because the muffs can not build the volume and pressure enough to get the water to exit everywhere
IF you had a large tank or barrel you could get enough pressure with the lower unit submerged. The muffs will work fine for the "back yard" work needed.
The keys to v-4 optimum cooling - Good impellar, good thermostats, good water deflectors and a clean water passage in the heads.
