1990 30hp Johnson cold start update
Mickeyblue
Hey guys,just wanted to let you know I got to the bottom of my cold starting issues!
It ended up being what I suspected,I had good flow from my primer but once engine was running it didn't respond to the choke.so I pulled off choke line to carb and blew it(brass fitting on carb) out with air and carb cleaner,now it starts right up like before,seems a bit of debri plugged off the brass choke fitting.
Hope this helps other members in the future!!
