Re: 1960 Evinrude 75hp disassembly mag/distributor
It should lift right of easily. Probably a bit of a burr sticking in the threads. If it won't come, use your flywheel puller or harmonic balancer puller (3 bolts). Did it have a thin flat washer under the lockwasher? If not, that probably is why it burred.
