I put the cover on the motor for the first time since getting the motor (1962 28hp rx-10) and its very lose. Its looks like I?m missing a rubber seal (part 0313173) which is no longer available. Just wondering if there is anything that I could use that would make the cover sit on the motor snugly. I have put some stick on foam around the base of the motor cover which has tightened things up a bit but it won't last long. I sure there must be some sort of door seal etc that would do the job. Any advice would be appreciated.
Regards Kevin
Regards Kevin
