stratosguyTN
- Oct 8, 2012
- 14
I recently replaced my fuel pump due to it malfunctioning. All is working well, except...... Once primed and unloaded from the trailer, the motor comes out of the hole perfectly. If I fish for let's say, 30 minutes, then go to take off, it bogs and will die if I mash to full throttle. I have to push the choke in for it to finally come out of the hole while Im at half throttle. Once on plane, it holds WOT at 5500rpm perfectly with no power loss. I have replaced the primer ball, fuel pump, spark plugs, and vapor separator gasket. I'm thinking its a loss of fuel and maybe it's getting air in the system somehow. When priming it, the primer ball gets very firm. Any suggestions? Any and all recommendations are appreciated.
