tj06civiclx
- May 24, 2013
- 17
Looking for some help, or direction in where to look...
The motor is a 1987 Johnson 88 SPL. We have been running off of an external gas tank. All of a sudden it felt like it was running on only 3 cyinders...
Got a compression tester from Autozone, tested the compression on the cylinders. 2 tested at about 100, one was about 90, and one was just under 90... I don't know how accurate the tester is (it looked like it has been used quite a few times)...
Anyways, put the boat in the water and ran it. Ran like it was missing a cylinder. Sputtering and would stall.
Johnson 88 misfiring - YouTube
Johnson 88 spl stalls - YouTube
We pulled it out of the water, and went to check the ignition coils, noticed the inner part of the wire (I believe it connects to the power pack) were very corroded and green. We cleaned them up a little bit, and put the boat back in the water. Started it up and it was MUCH better. Still sputtered a little bit
Johnson 88 spl no cover - YouTube
We took it for a spin, and it was running fine. Accelerated fine, drove fine.. Then after a few minutes it went back to sputtering...
Thoughts??? We are thinking we a good cleaning of the wires that go into the ignition coils (or replacing the power packs) and possibly new ignition coils.
We already have a good amount of money into this motor...
