Spanish#007
- Jul 31, 2013
- 28
So my boat was running like poop last time I took it out....the only thing I did was pull the plugs and sand them down with some 180 grit and put them back in at 18 lbs of torque...anyhow, now my boat either isn't getting gas or spark, I checked the spark of the plugs at 1/2 and didn't get any to fire, changed it to 3/8 and cyl 2 and 4 were good, 1 and 3 wouldn't fire until it was about 5/16" (1st thought was power pack on that side). I then went on to test the ignition coils which came back at the correct #'s per my manual, I tested the primary and secondary resistance on them.
a fuel kit pump was done in the past two yrs, also I tried pumping the primer bulb while running to see if it would help and it didn't' seem to make a difference so on to testing the ignition system.
When I did the Charge Coil resistance test I came back with 302, my book says it should be between 485-600...It isn't clear whether there is just 1 charge coil or two...the reason I'm wondering is because my boat basically has two identical systems, with 4 coils, 2 power pks, ect... The charge coil tested at 302 on both sides, if there is only one I understand, and I might think it was bad...if there is two and they are reading the exact same I would think they are good. Anyhow I can't seem to find a "charge coil" anywhere? I found ignition coils but not charge coils.
Per my manual there are ignition coils, charge coils, power packs, and sensor coils....odd as my old boat just had one CDI that included everything and one ignition coil....much easier to diagnose, but also more expensive to replace. Moving on....
I dont' have a DVA adapter, looking at buying one today....my book calls for a CD voltmeter, which seems to be the same thing with a different name. Anyhow, goes without saying I couldn't test the power pack output, charge coil output, or sensor coil output because I didn't have the tool !!!
So the charge coil resistance test seemed to be off per above statement (tested 302 Clymer states 485-600). The test I was able to perform with my regular multimeter: Power pack Isolation Diode Test, PASSED. Ignition Coil Resistance Test, PASS. & Sensor Coil Resistance Test, PASSED. So they all passed, now it seems I need to get a DVA adapater so that I can do proper output test
Does anyone know where to get a cheap DVA adapter or CD Voltmeter?
Does anyone know where to get a charge coil for a 1978 Evinrude 140 hp model 140843C?
Does anyone have any other suggestions?
Thx a million!!
Thx a million!!
