Ron Sanders
- Jun 9, 2005
- 2
Hi, I have a tracker Evinrude motor model#TE40ELCEC ,1989 I am getting a lot of oil in my water barrel while running my engine and trying to get it running right. The best I can remember it started this after tacking the vro off and plugging the lines. I have checked the water jacket and changed gasket that didn't look bad (didn't work). I then pulled head and replaced gasket, the upper cylinder looked like it had been washed almost shiny clean and the bottom cylinder looked a little carboned but just normal, nothing significant. The engine is running on one cylinder, I also rebuilt the carbs and checked comp. 145lbs. both cylinders. I have been told it is a crack in the water jacket that you can't see, with good comp. I don't understand how this could be. I have run out of options, is it possible taking the vro off has something to do with this? There is enough oil in the water that i stick my hand into the barrel, it coats my hand with heavy oil.
I am at my wits end, can someone help,please?
