Re: 50 hp evinrude outboard '88-'00 CONVERT VRO FUEL PUMP TO STANDARD PUMP
simple to do
take complete fuel pump off the engine. disconnect the plug on end of wire from vro plug and tape it up.
the wire that comes from the oil tank to engine again disconnect the plug and tape it up.
disconnect oil pipe from tank to engine at engine end. take tank from boat.
now just get new (old style) fuel pump and place it in the engine compartment and attach fuel pipe from fuel filter to the fuel pump
then the fuel pump to carb pipe then the pulse pipe to fuel pump.
make a small simple bracket to hold pump and job is done.
Now before putting fuel into to see it all work etc,just start the engine up and it will probably die within a few seconds due
to carbs emptying out of oil and petrol.
Now just fill tank with fuel and make sure you add the 2 stroke oil at 50-1 ratio.
and in future you just simply mix fuel and oil 50-1 and enjoy the boat.
standard pump is simply this....fuel tank to fuel pump to carbs !!!! yepit is that simple.
you will not get any low oil alarm, but will still get a over heat alarm should the engine get too hot.
phill
