I've been in the process of using up a good portion of the 83 gallons of fuel that's on board my boat to get better information as to how the boat preforms with a lighter load. The 53 gallon tank is getting close to being emptied. Will I have any issues trying to start the engine other than having to prime the engine if I allow it to run completely out of fuel since it's direct injection? I know with a diesel that's a no no, cause the air has to be purged from the fuel system. I've never run a direct injected gas powered engine out of fuel before.
