Primer solinoid-evinrude 110hp
EVANGL
GDay All
Will a faulty Primer Solenoid influence performance at WOT.
Cheers
Glenn
Daviet
Re: Primer solinoid-evinrude 110hp
If you have it in the manual position or the solenoid is bypassing fuel, it will add extra fuel to the intake and cause problems.
boobie
Or if you have some stray current in the system energizing it.
emdsapmgr
If any of the hoses are cracked-leaking air into the system.
