Serveral years ago, I was given a 78-79?? Johnson 115 hp motor. I didn't have much trouble getting it to run and took the boat to the water. It ran fine for a couple of trips then sat up for a year. When I tried to start it again, I couldn't get it to start. I took the carbs off and cleaned them, cleaned the fuel pump and fuel lines. I reset the choke plates to the specs in the book. Now the question: With the switch "On" the choke closes when the choke switch is activated. But when I turn to "Start" the choke butterflies open up and won't start. I visited this site right after I got the motor just looking for information on this motor. I seem to remember someone with a similar problem but I can't recall the solution.
