42653stevemotorcycle
- Jul 28, 2011
- 8
I need info on the ignition switch for a sylvan pontoon with a 40 H.P. Johnson. I think the ignition switch was replaced and wires hooked up wrong. The switch has 6 wires m,b,m,i,s, and the middle c. What color wires go to which terminals. When you try to start the motor it has a key electric choke and when you turn the key to on and press the key for choke it starts.
