1993 25hp Johnson tiller to remote conversion.
Status
Not open for further replies.
gscott87
I have a 1993 johnson 25hp tiller motor that I am wanting to convert over to a remote control setup. I am having trouble finding all the brackets to steer the motor and brackets to control throttle and shifter. I have done alot of searching and saw some different mounts using the through tube and a arm to steer the motor and a setup not using the through tube just using a standoff type conection on the transom. If anyone has done this mod and can give me some info i would apreciate it. If there is a kit to be found I cant find it. Thanks for reading. The motor is a J25teets.
cpost22p
I am wanting to switch my remote steer to a tiller steer. I have a 25hp 1990. Should be a direct fit. Want to just swap all equipment?
oldboat1
Start a thread of your own, and explain what equipment you have.
Status
