Forester 150
- Aug 24, 2013
- 2
I have a '88 Forester w/ Evinrude 150hp that dies if you try to go over 1500rpm's in drive while on a lake. It tests out fine with muffs and runs good in neutral and reverse on the lake. The alarm did sound a couple of times, so the VRO was checked out to make sure it is operating and the lines/ filters are clean and primed. I also replaced the plugs and checked water flow.
