Re: 71 Johnson 60ESL-71C Drive shaft removal
Hi Neil,
Do I see it correctly that the reverse gear is in a lot worse shape than the forward gear?
If so, clean up the reverse gear (if it requires, it is hard to see from the picture) and you might chance to re-assemble things with a new dog clutch and pinon gear nut, and try to use it.
You also mentioned that you are getting really good at taking that thing apart ;-)
Those pieces that are missing from the gears, were they in the gear case with other metal pieces and shavings, or the mishap happened before, and at a previous repair those pieces were removed? If so, then those gears did work for some time with those pieces missing without causing any further damage!
BTW, the service manual says that inspect the gears (and other pieces), and replace them if worn ;-)
Are those gears still available? Are they expensive?
Good luck, Peter
