CaneCutter79
- May 24, 2009
- 454
My timer base is lagging. When you engage the throttle lever, it moves forward but the timing lever hangs back (doesn't move) until you engage the throttle full and then the spring inside the throttle lever engages and finally the timing base lever jumps forward.
I found a slight adjustment that was off and engaged the carb too much causing flooding carb/fouling plugs and combined with the timing not advancing.
Is there a fix or do I have to find another timer base?
