HI,
I have a 2000 Johnson 200 hp model J200PLSSC on a 19ft Stratos 19SS Extreme bass boat. I have been fishing about every day the last two summers. She has got a lot of use in the last two years. The last two trips i had the low oil and check engine light (bottom two lights on the system check gauge) come on for a few seconds with alarm and then go off. The first time it occurred at take off the second was right after take off. No other lights come on. She goes through the normal light sequence at start. She smokes some at start up, but runs great.
I started imaging she was not using as much oil, she was running slower, etc... But, i think it is in my head.
I have bought a new VRO/OMS pump, T-stats, oil filter, and water pump kit for maintenance.
Any ideas about the lights?
