denzil1300
- Aug 8, 2013
- 9
I suspect motor is in SLOW mode. Starts missing at 1/4 throttle and shakes real bad as throttle is increased. Won't rev up as normal. Motor does not have oil injection system so it is my understanding that the temp sensor is the only thing that could cause SLOW mode to engage. To get it out of SLOW mode I disconnect the connector in the tan wire leading from the temp sensor to the powerpack then ground the tan wire coming out of the powerpack. I assume it needs to be grounded with the motor running. Then shut off motor and restart with the temp sensor still disconnected. If it runs normal then either its overheating or temp sensor is bad.
Just wanted to get confirmation that above is correct procedure to get motor out of SLOW mode. Thanks for any help.
Denzil
Denzil
