Hello All
I have a Evinrude Intruder 175 hp # VE175GLETR (VRO REMOVED before I bought the boat) Just bought the boat. (1994 Bayliner Redevous 2609)
The engine has had this problem for awhile.
Boat starts and idles fine, runs slow fine, but when you run it 3/4 to WOT it will run out good the BAM it just shuts
off. Put it in neutral pump the bulb and it fires right up and runs fine, until you crank it out again, then BOOM dies again.
The previous owner had all new carbs put on ( I mean new, not rebuilt, wow that was expensive) a tune up, last year
and it still did not fix problem. He ran out of money, so he just putted around and it did fine.
Any Ideas ?
Any Ideas ?
