I've had this boat out 2 times since I got it running about 6 gallons thru it each time and it runs great, however, the plugs are a light tan evenly. The 2 bottom cylinders are the lowest compression (100 &105) and they are a little darker. The other cylinders are about 115 PSI. I ran the boat at full throttle a bit and about even split between half throttle and idleing around.
I'm a little concerned the motor is running lean as per the plug readings. I've been reading and from what I gather the idle screws should be approx. 3 turns out on some motors and 5 on others. I checked the top 2 and they are 10 & 1/2 out! Are these "idle air" screws or "fuel screws"? In other words, the further out the screws are the richer... Or the reverse? It seems to me the further out the richer.
Is there something odd about that?
Is it possible I may need to go up on the idle jets since the idle screws are so far out?
The motor spits or coughs a little at idle when the motor in in forward and at about 800-900 rpm.
Any help is appreciated! It seems like a lean condition even though the moter runs good, I don't want to burn it up!
Please help.
Please help.
