salmonplease
- Aug 18, 2013
- 2
Hi,
I have a 1986 j50belcde, VRO disconnected, it has a small miss at idle and a flat spot at 3/4 throttle (don't have a tach), full throttle is fine.
Carbs rebuilt, new fuel pump, new plugs, new head gasket (all professionally done) engine had been sitting for 3yrs
Does anyone know the factory size jet numbers? My top carb jet is 32, my bottom carb jet is 36.
Are the jets supposed to be the same size?
Does anyone know the factory size?
Could this be the problem?
Thanks in advance,
Brian
Thanks in advance,
Brian
